Re: Help Rust under clear coat..
looks like the tins weren't completely cleaned and dry before coating, or that rust was already there. once properly coated, you won't get rust, whether you use color or clear.
on the lines, crisp lines require good masking. you're always going to have a 'drop off' point between the powder and metal though. thinner coverage will create less of an effect, and the clear can help mask some of it as well.
