  #9 (permalink)
Old 06-08-2007, 12:33 AM
fl70 fl70 is offline
fl70 is an unknown quantity at this point
Default Re: Help Rust under clear coat..
Originally Posted by baz
any humidity ,oil , or acid on your skin will affect the metal . alo being from a 2006 has nothing to do with it as soon as your metal has been stripped ,sanded or blasted, oxidation starts .the better you clean and the fastest you coat it better are your chances that rust ill stay away longer
Have to agree with baz.
Always wear latex or nitrile gloves when handling parts.
You could give the bare area a light sanding after curing the satin black, wipe it down with pre, dry, then shoot the clear.
For slightly cleaner lines, press the edge down firmly and leave the tape for the duration of the cure.
It ain't your grandma's box!!
