Old 06-19-2007, 11:04 AM
jrow jrow is offline
Default Re: Suggestions for a cast auto intake
y2kgtp,
When your in the process of striping the intake use a plastic scraper so that you don't scratch the aluminum!
If the manifold is fairly smooth other that casting remains, I'd take care of the casting remains first, then try some emery on a sisal buff. You may not have to sand depends on how the aluminum is after you have it stripped! If it's to rough then use some greaseless and then move to the emery.
John
