Re: 1st power up...ALARM ??
Appearenty yours only has an alarm "on" setting. It's #2 or "SHP" in the table. To shut the alarm off, set the SHP parameter to some high value--999 or the like. You need to press and hold the SET button for more than 5 seconds to enter the parameter loop. It doesn't say how to step through each parm but I imagine you press the set button (do not hold) when you reach each parm to change then use the up/down buttons to change the value in the display. The parm you need to set to 999 is the first parm. Once it's value is set, press and hold the SET button for more than 5 seconds. *** The values have negatives so make sure you use the Up button to increase out of negitive values. ***
Also note that if you have the AUTO set, it is reset to zero (off) when you enter the parameter setting logic. To turn it back on, you'll need to loop through the parms until you get to AT then set it to 1. Then press and hold SET for more than 5 seconds.
Front Panel and Parameter setting loop.
1) Press SET and hold over 5 seconds to enter/exit the parameter setting loop.
2) Parameters adjusted are:
SHP→Sc→SOH→P→]→d→t→At→LoK
3) When in the parameter setting loop and no keys were pressed
for 30 seconds, it will automatically exit and parameters adjusted
will not be valid. (Not Saved)
(To exit with adjusted value saved, press SET over 5 seconds.)
4) When in the parameter setting loop, if At=01 is being set, press
SET over 5s to exit. Then At indicator will be on and Auto-tuning
will take effect.
5) Everytime entering parameter setting loop, Auto-tuning will reset to At=00.
6) To prevent other change parameters, LoK values can be set to 01 or
02 before exiting parameter setting loop.
