Correction: The SHP parm is actually an off set for the target temp. The alarm lights when the off set is reached. Evidently, yours is set to zero or a negative number. By setting it to a positive value 999 or the like (as stated before), it should disable the alarm light. It means it will come on when the target temp + the off set is reached. Hopefully, you should never reach that temp.
