Old 06-20-2007, 09:31 PM
tbreaden tbreaden is offline
tbreaden is on a distinguished road
Default Re: Best Blast Media
Maybe you can find a local company to do your blasting for you. because you have to get the chrome off and clean the pits out. then I use the MetalX stripper to strip the nickle,you have to heat this to 130-150f with aggitation. It gets you down to the copper and it will eliminate alot of pits (and work)that are not into the pot metal.. Then you can try the pickle #4 it is a deoxider and activator for zink die cast. Todd Breaden
