Originally Posted by raelayotte
i have some chevy aluminum rims for my chevy blazer and they and in need to be redone i know i should sand them starting with 150 and so on to 600 but is there some thing i can use with my air drill to move it a long a little faster. i will have some pic here soon to show u what they look like so u all can help with my new process
Use Aircraft Stripper to remove the clear coat. You may be able to take the scratches out with some 320 or 400 grit wet and dry sandpaper and then go directly to polishing!
Air Drill: You can use some flap wheels to reduce your manual labor time. Get the diameter wheels that fit the curvature of your rims!
John
