Re: Turned the oven on for 1st time - Fireworks!
Using a PID controller with a SSR gives much better temp control/stability.
The controller "pulses" the SSR as the temp gets close in order keep the temp as steady as possible. You could do the same with a contactor but you'd wear it out pretty fast.
