Old 07-10-2007, 03:41 PM
cbrooks's Avatar
cbrooks cbrooks is offline
Caswell Inc Staff
cbrooks is a glorious beacon of lightcbrooks is a glorious beacon of lightcbrooks is a glorious beacon of lightcbrooks is a glorious beacon of lightcbrooks is a glorious beacon of lightcbrooks is a glorious beacon of light
Default Re: Immersion plating using PNP solutions and adjustable power supply
You are over powering the item. Which means that you are burning the plating. You may need to increase the distance between the item and the wand or process more pieces to increase the surface area that you are doing. The voltage is really not that important it is the amperage. The 1.7 volt unit only produces 300 mA.
Craige Brooks
Have A Web Site?
