  #8 (permalink)
Old 07-25-2007, 03:02 AM
Blazin_Jason Blazin_Jason is offline
Blazin_Jason is an unknown quantity at this point
Default Re: Spreading Lab Metal
What are you coating? Were you able to get the LM local or did you order online? I tried to order it off here, but caswell wouldn't ship to Canada, so had to get it from alvinproducts. Did it bubble where the filler was feathered and thin, or everywhere? When I did the harley frame I didn't use any solvent. Didn't quite air dry for 24hours, but I did toss it in the oven while we cured something else. Did that for the 2 applications before pretreating and coating. Couldn't even tell that it was filled. So far so good.
edit: I saw in your other post it looks like it was a range hood. Are you using a urethane wrinkle black? If so that could add to your problems.
