Re: Spreading Lab Metal
I wouldn't bake it to speed up your set time.You can start working it after a couple minutes of putting it on.I do my rough sanding with 60 grit, then after about 24hr. it should be fully cured.Then go back over your piece with real thin coats until you get the part where you want it.I would wait till cured before puttin it in the oven.
