  #8 (permalink)
Old 07-28-2007, 06:46 AM
grommit's Avatar
grommit grommit is offline
grommit will become famous soon enough
Default Re: How to get internal crevices?
hello Cruizer, i had a nightmare just like you with crevices,really done my head in and i got the same advice with cratex, i thought these were the top dogs! but i did find that they did wear down very quickly.
a novel way is making sanding heads for my dremel with the desired sandpaper the right size for the crevice,but ya have to make sure the sandpaper is attached tightly or they will be heading off over your garage at mach3 or at u at worse.have you researched GREASELESS? using that on your mini bobs can be the answer.
take care
Grommit
