Old 07-29-2007, 01:26 AM
BDForgan BDForgan is offline
BDForgan is on a distinguished road
Default Re: New Anodizer-Tank Set Up Question
I didn't think about a hot plate. Great idea for a future upgrade when I feel I'm consistent with the current set up. I guess i was focused on not using ANYTHING but HDPE plastic and aluminum.
Can any of you guys or anyone else answer the last question – does the part in the sealant tank have to be hung in the middle of the solution or can it rest on the bottom of the tub? The instructions says to leave it in the tank for 15 minutes. That's kind of long to be standing there swishing the part around by hand. I'm assuming the dye tank requires the part to be hung in the middle of the solution because you'd want to make sure the dye gets absorbed evenly around the part for another 15 minutes. The Degraser and DeOxidizer\Smut tank only requires 3 minutes, so that's easy to do by hand.
Thanks
Bruce
