Re: Alternator, Bearings?
I've been inside quite a lot of Ford alternators over the last 3 decades, and never had any trouble removing/replacing the bearings in them. I've been inside a few Mopar alternators and don't recall any without replaeable bearings. Dunno about GM/Chevy... they irritate me too much and I stay away as best I can.
Even cheap **** alternator with non replaceable bearings, you should be able to plug/mask off the steel bearing part with a little effort and anodize the rest.
I've had good luck using rubber cement to mask off steel inserts or fittings in parts to be anodized. Let it dry good first...
