  #9 (permalink)
Old 07-30-2007, 02:06 AM
sswee's Avatar
sswee sswee is offline
Moderator
Default Re: New Anodizer-Tank Set Up Question
Originally Posted by hvacman250
Ceramic heaters are fragile and break all the time. Titanium heaters are better overall.
Another note on this. More than once I've had a ceramic heater blow up in a tank. They pop on occasion and you won't know they've blown up every time. If you stick a metal part into liquid, with wires in it, plugged into a wall outlet, it will light you up and good. It's a very good idea to use GFIC plugs on anything around liquids. Just for ya'lls amusement and laughs. Last time it happened, I was sticking a Ti rack full of parts into sealer. As the rack touched the sealer, I was sent into a quiver and the lights went out. The GFIC popped the circuit and I was standing in the dark, hollering for my son to bring a flashlight so I could do something without messing up the parts I had just run. I changed out the blown heater and finished the job but had a little tingle for a bit.
SS
