Originally Posted by y2kgtp
Well, that first, if the buffer is smaller than the stand, else the wood adapter.....
No not really. If the buffer is smaller than the mounting plate you cut the mounting plate to the size of your buffer base. That way with the bigger things that you buff, you won't run into the mounting plate! Also if the corners of your mounting plate stick you from under the buffer, you want to cover them in slit rubber tubing! Nuff said.
John
