Old 08-01-2007, 08:03 AM
Harleydad's Avatar
Harleydad Harleydad is offline
Default Re: Powder Coatings Rims?
Originally Posted by donafams
When dong a chrome rim, you must scuf the surface with a scotbrite pad first right? If you're using a solid color, then yes. If it's a transparent/candy color, no.
What about doing an alluminum rim? and how to tell if the rim has a clear coat on it already? Same thing applies to an aluminum rim.
You could try a little stripper in an unconspicuous area or a light blasting. You should be able to tell if there is anything on it.
