Originally Posted by outcastzeroone
At work we tried useing some of hte caswell Solar Flat Black on a peice for a car we where working on. It had a couple of shiny spots on it and a booger so we sanded it down and reshot it with the flat and cooked it at 175 for 12 min. Only when we pulled it out it was gloss/semi gloss and not flat at all.
Has anyone had isues useing the Solar Flat Black before? Did we screw up on the second coat?
solar flat black is noticibly more tempermental to apply than, say, super wet black when using a less expensive gun. double coating compounds this problem a lot. as far as it turning to semigloss, i haven't experienced that. were the lines clean? i've got to believe some kind of contamination is causing this. ...either from the gun, or on the part.
