  #8 (permalink)
Old 08-04-2007, 12:30 AM
hvacman250 hvacman250 is offline
hvacman250 is on a distinguished road
Default Re: Part performance after anodizing
Hhmm...I'm starting to hit a few roadblocks after a few months of awesome results. I'm starting to wonder if my stripper is damaging parts.
Its a few months old, and has probably stripped a few hundred parts. Does it need to be replaced yet? It still works, per se.
I clean the part, drop a few pieces in, wait a minute or so, then scrub with a toothbrush. Back in and scrub until all the dye is gone. Rinse good then desmut. It probably stays between 75-78* in a semi-cooled garage. Average time stripping is 5-8 minutes.
If the part is pitted, do you see pits in the aluminum? Like visible stuff? Can the part be salvaged from pitting?
Here's a problem I encountered last night:
Click on pic to make it bigger
Appears to be 6xxx aluminum, stripped fine, but came out of ano weird. Looks liek flaking in the metal itself. Scaly almost. Any ideas?
I'm getting a gut feeling something has changed. I was wondering if it wasnt my acid bath, but Im starting to blame the stripper. Kinda confused ??
