The only other thing I can suggest is get a pump sprayer (make sure it's clean... no grease) and spray a steady stream into the thread areas after ano.
You can get Ti rod if you want to go with something a little more robust here:
www.onlinemetals.com. The Ti rod threads easily, and is re-usable.
