Thread: Gato Parts
Old 08-23-2007, 08:58 AM
Merriman's Avatar
Merriman Merriman is offline
Sub Building Guru
Merriman has much to be proud ofMerriman has much to be proud ofMerriman has much to be proud ofMerriman has much to be proud ofMerriman has much to be proud ofMerriman has much to be proud ofMerriman has much to be proud ofMerriman has much to be proud of
Default Re: Gato Parts
Originally Posted by wcb1863 View Post
Any chance that you have a list (even tentative) of those parts or components that you don't provide in the kit, necessary to complete the Gato conversion. For example: stainless wire (total length and size) for rudder and dive planes, servos type and number, battery, speed controller, couplers, etc. Would save many trips to the hobby shop.
Thanks,
Walter B.
Damn good point, Walter.
I'll work up a list for you and the other GATO r/c submarine drivers out there.
Ellie, Rose and I just got back from the Carmel SubRegatta. After two days of running the prototype r/c'ed Revell GATO in the water there I'm pleased to report that the boat performs very well: a tight turning radius and depth control is positive and rock solid. I like this boat!
Run time on a 2000 mAh pack was about thirty-minutes ... not bad!
David D Merriman lll
