Re: for those of you that use professional guns
Use the hopper for colors you'll have on for some time. Better fluidization. I have some jobs that are 400, 500 parts. Box feed is fine if you change all the time and I can chance colors in less than 10 min. I don't like to use the 55 lb boxes just because of the weight. It seems to get compacted even though the part it sits on only vibrates when the trigger is pulled. Seems worse this time of year (humidity).
