  #32 (permalink)
Old 08-29-2007, 11:40 AM
SLOSteve SLOSteve is offline
SLOSteve is an unknown quantity at this point
Default Re: PLATING POT METAL...............
Originally Posted by 48Buick View Post
Bryan:
The biggest thing with potmetal is to just stick with it until you learn how to deal with it. Its the hardest metal to plate.
Practice a lot on scrap.
Good luck and let me know if you need any advise.
48 Buick
Sticking with it is the key! I'm living (still) proof of it. When you mentioned pulling your hair out before plating pot metal you were right. UGH. What a pain but it is fun learning as long as I take a day or two break when I get frustrated.
I've been working on a pot metal radio bezel for quite sometime. Being the really smart guy that I am I didn't start out with the copper pipe practice pieces and went straight to the pot metal (if I'm going to plate pot metal I might as well USE pot metal to practice on, right?). Anyway, to make a long story short I screwed it up so now it IS my practice piece!
I have a couple of quick questions: First, does the part need to be polished to a mirror shine before each plating process, and second: activated in 33% sulphuric acid solution just before the next plate? I think I goofed when I mixed pool acid at a ratio of 1pt to 1gal of distilled water. It should be stronger than that, yes?
Btw.......add me to the list of people you have helped a LOT with your pot metal plating experience and procedures!
