help removing rubber cement
I just made my very first attempt at a splash anno on a chunk of scrap aluminum and I couldn't be happier with the results, except for one thing, I can't get the rubber cement I used to mask to come off of the workpiece. I've tried scraping it off, I've tried steel wool, I've tried heating it off with a hair dryer but this stuff has a death grip on my workpiece. I let the rubber cement dry for around 10-15 minutes each time it was applied and right now I'm letting it dry out more to see if that will help.
I'm a little wary to start using solvents to remove the leftover cement since the part has yet to be sealed and I'm afraid it might remove the dye that I just spent almost 4 hours on.
anyone know how to remove this stuff or know of an easier to remove alternative?
EDIT - I was thinking of putting the part in the oven to try and bake off the cement but the bottle says flammable and I don't know if that's only while it's wet or if it's flammable while dry too.
