Re: Silver Plating for Musical instruments
Sounds like it was plated with to much voltage. What is your cleaning method?? Did you do a water break test prior to plating?? What type power supply were you given ?? How "warm" was the bath?? There is only a small amount of silver in the plug and plate kit and if you use the stainless steel anode you will sooner or later deplete the silver content.
Bill
