Pot Metal Plating questions
Sorry, I'm just getting started and this is a long one.
I have some pot metal pieces I'd like to restore for my auto restoration project.
Of course after 30 years there is some pitting ranging from light to exploded type.
Whats the best way to remove the old chrome/nickel and prep the surface? Whats best to fill pitted areas that need to be drilled? Does every pit need drilling or just black areas? Also during an immersion replate do all other types of metal (steel hardware etc) need to be removed - will damage result if they arent? If so can they be coated for protection during plating?
Finally I'd like a show chrome finish. Would Electroless nickel followed by copy chrome work? Pot metal primer? Flash Zinc? Whats the most trouble free system to plate pot metal parts swithout going through too many steps but that will also address hard to plate parts?
Was also looking for 1/4" hole buffs but couldnt find any on your site (which is great by the way). Do you have em in 1/4"
for use with my die grinder or drill?
Thanks in advance.
Dave
