Thread: modular oven
  #10 (permalink)
Old 09-25-2007, 08:54 AM
gomer950 gomer950 is offline
gomer950 is on a distinguished road
Default Re: modular oven
building a panel that will lock together to make a straight wall is easy. have have thought of many forms of these. my bigest promlem is how to make a corner without the need for a special corner panels. and how to also make the top and bottem work out around the edges. the next big problem is keeping heat loss to a minimum at the joints. 2 flat edges with insulation material in the middle would work, but is there a better way that the edges could be shaped that would solve all the issues of heat loss and conections between different walls.
this is a good problem for all you mathmatitions and desigers out there. any good ideas that you can think of or have seen someplace? if you can post any pic's to help your expination would be a major help to me, i'm a very visual person.
