Re: modular oven
"my bigest promlem is how to make a corner without the need for a special corner panels."
You only need 2 of these corner or end panels, no mater what size oven you assemble, it has a left and right end, always use the same panels for the left and right ends for any length.
You can build this so many ways, I can't explain in plain text very well though.
Make each panel so where they connect at the ends they overlap about 2-3" and only half as thick, over lapped and fastened the overlaps are full thickness. So if you build 3" thick wall panels, the ends are 1.5" thick and overlaped make the 3" from 2 panels.
