Re: oven build help,with pics
HI Grommit,
I left a post for your other freezer, same thing here.
Also I should have mentioned that if the insulation of the freezer is good when done, then it will heat up ok with more or less elements normally, just takes more or less time really.
I would start this one also with a working junk electric stove as I said for your other freezer/oven post.
You found a couple great looking freezers, I hope you can find a couple good stoves for donors also.
