Re: Oven using metal studs and aluminum
Thanks, I'll go look. By the way the oven is still going strong after a couple of years. I had to add aluminum panels to shield the elements from the parts, they were heating the part with IR too much, instead of air temp. Some parts were 50 degrees hotter than the air temp!
