Old 10-13-2007, 05:56 AM
grommit's Avatar
grommit grommit is offline
grommit will become famous soon enough
Question Re: oven parts help needed
for the thermostat or pid controller . look on ebay for (pid controller) i suggest you check with your electrician an then call the seller to make sure it is compatible with your electrical supply .you will also need a relay that is compatible with the controller and your electricl needs to drive the elements
[/quote]
hello guys thanks so much for your replies, please can anyone explain in non confusing electric speak what a PID is and what it does, i am assuming it controls the heat? i think a thermo coupler reads the heat, and will it be dispalyed in the PID, in theory i am better off using a donor oven as even i can trace wires etc, dismantle and then get a electrician to put it together, obviously the heat up times will be longer but hopefully the desired effect will be good.
i would be happy to buy all new parts but i just do not know what i need well apart from a 3000+ watt element for now.
many thanks,
