Old 10-14-2007, 08:13 PM
MrPontiac MrPontiac is offline
MrPontiac is on a distinguished road
Default On going power supply question??
Its got me scratching my head,. i can be going along copy cading parts then out of the blue i loose my voltage and my amps go way up, I know i thought i had a bad connection, i check all my wires, i have a jumper between my anodes witch now are new, there perfect visualy, my black wire connected to the copper pipe is perfect, im using a copper wire connected to a brass hook, its ok,, My power supply has a button next to the voltage scale, if you hold it in or tape it in the voltage reads good then?? Im stumped here ive tryed everything, could it be the red jumper between anodes, its just a thin wire electrical jumper with aliagator clips?? I can plate a few more parts and then its works again?? Looking for suggestions, anybody??
