  #9 (permalink)
Old 10-16-2007, 10:28 PM
baz baz is offline
baz has a spectacular aura aboutbaz has a spectacular aura about
Default Re: What am I doing wrong?
Originally Posted by jpmassey View Post
I am using a Motorgaurd air filter, and a coiled copper air cooler. I never have used oil in the lines. I figured the phosphate and water wash would take care of any towel dust particles. I have seen a couple feathers here and there, but they are around sharp edges, etc, not in the middle of a flat spot.
I'll use a different can of powder next batch.
I may be only shooting textered powder if this keeps up.
oil could be coming from the compressor. try blowing air on a white piece of paper for a while and check if it gets wet or moist or if it has some oily spots on it .you can add another filter just before the gun to help .
using texture powder will only hide the problem . better to spend alittle tim to find and fix the problem then all your jobs will be better looking
