  #11 (permalink)
Old 10-25-2007, 07:06 AM
mpierich mpierich is offline
Default Re: T6-6061 Aluminum sanding questions
Originally Posted by baz View Post
i havn t done shovel head cases for a while but caveman castings is probably an understatement i that case . for the tight areas i make my own cartrige rolls
i have different size and shape mandrels with a split opening so i insert and roll my abrasive paper on it , might sound caveman type way of doing but i get the roll the size and shape i need in the grit that i want . have a look at my vrod engine in the member galery .i dont like working with real cartrige rolls
the tips wear out too fast i go through a box of 100 in no time
Yeah, I had forgot about the split mandrels...since I usually stop around 320-400 never really needed 'em. Now, if I ever have time to polish my _own_ stuff, heheh...
For the cart rolls, I got extra mandrels in the various lengths. Nip off half the smooth end part and you can use it for worn rolls - get twice the use out of them.
