Re: On going power supply question??
You can get rid of that green corrosion in a second or two by dipping your copper pipe in a bath of #4 pickle. I have a special bucket just for this. I also clean the pipe at the end of a plating session so that it can dry. Don't want that pickle in your plate solution. If you have an air compressor, it helps to blow out the inside of the pipe after you pickle it.
Pickle it
Rinse it
Compressed air (if available)
Allow it to dry.
