Originally Posted by shoblue
Thanks for the replies! I have some supplies arriving tomorrow - I ordered some 6.5" loose cotton's, a 6.5" spiral sewn cotton, and a 3.5" mushroom. The drill I'm using is a Rigid 2500rpm. Will the larger wheels make a difference? With the 6.5" buffs the speed will be about 4000 SFPM. With the 4.5" buffs that came in the kit the SFPM was about 2800. Also, what compound/buff should I go back to, to work out the "lines"? Thanks!
Rich
Try dropping back to black and examine it closely to see if the "lines" you're seeing are gone. Then work your way back up. The canton might not have much effect except for a final coloring with white or red rouge.
