Re: can i use this power supply ?
Daz,
It looks like that PSU should get you started. Just keep in mind that 12 sq. inches is probably not as much surface area as you think. It should get you started though. It also looks like that is a dual output unit. If so, then you can bridge them in a parallel circuit and double your current output. Voltage is not your significant factor, so just set the voltage to 1/2 ~ 3/4 setting and leave it there to begin with.
