Re: oven parts Q:
Panman, It would help if you could ask more specific questions. If you are totally new to electronics and wiring you might need to find someone to help you with this aspect. As these ovens typically use 120 and 240 VAC there is a real danger involved if they are not wired correctly.
Lookup some of the wiring diagrams posted here and see if that doesn't help get you started.
