Re: can i use this power supply ?
That looks like a decent power supply to me. Better than what some are using. From what I can tell, the only reason to purchase a different power supply is if you want to plate more than 28.5 sq. in. S.A. (zinc). Remember, amperage is additive when you connect power supplies in a parallel circuit. Therefore, your current PSU will allow you to purchase a cheaper fixed amperage PSU (say 3 or 4 amp) to increase your plating capabilites. You connect them in parallel and then do the fine tuning with your adjustable PSU.
