Re: Verticle Elements Leaning
Might depend on the type elements or something, but I think you can just make a metal bracket perhaps.
Look at an electric stove. If you have a similar type element, the oven ones often just lay in a metal bracket. The top Broiler element in a stove I have was only held in place on the end by a stamped sheet metal type bracket which it sat in and the bracket was screwed to the top of the oven.
If it works for a cook stove oven should work for a PC oven.
