  #9 (permalink)
Old 11-09-2007, 11:16 PM
Rasper Rasper is offline
Rasper will become famous soon enough
Default Re: Adjustable Air Mini-Die Grinder Advise Please :)
Electric drills are designed for drilling. Most of the force is straight in line with the motor shaft so the bearings don't have to withstand much side thrust. The opposite is true with polishing. It's all side thrust. Electric drill bearings just aren't up to it. Hence the wisdom in using cheap used throw-away drills from yard sales.
Richard
