Re: white ano
i use powder coat. bead blasting = sand blasting with glass beads or pellets. or could be other blasting media, but i think beads are usually glass? if you're anodizing, i don't think blasting is the way to go, bc it'll leave a rough finish that will make the anodizing look bad, but then i don't anodize.
Len
Figure Engineering, LLC
