Can I strip the zinc off new commercial fasteners by just using muratic acid?
Yes.
Mix it 15-25% w/water. Full strength will strip the zinc fast, but will also etch the raw steel. The weaker solution takes about 5-10 minutes to strip the zinc, but doesn't hurt the steel. The zinc fizzes as it dissolves. Pull the parts out when the fizzing stops.
Is "copycad" a good surface? or does it have to be zinc?
CopyCad is zinc.
Sean
