Re: Hello everyone!
The manual for your PID is available by searching ColdfusionX TET612, looks like a reprogram of the PID J2 terminals as directed in previous post and a quick check with a voltmeter would do the trick, but.... if you were to get and SSR (8volt) with a heat sink,in the long run, you might be happier. You can do this with a single pole SSR , just wire up the elements like most electric stove elements are wired with only one legg switched. Good Luck. FRED
