Re: Anode + tank bar question
Definaltely the tank bar must not come in contact with the anode plates, if it does you will short out the power supply/rectifier.
I would suggest rotating the tank bar 90 degrees so it runs between the anode plates parallel and positioned evenly between the plates.
Hope this helps
Cheers Mark
