Hi
I need to plate lots of small brass screws and was thinking getting a thin strip of steel with holes drilled in it to hold the screws.
What I want to know is as brass has to be activated will the steel do this for all the screws and will the strip of steel plate as well? So when I need to plate more screws will the strip, which is now plated, still activate the brass? Or clean the nickel of the strip back to steel?
hope thats clear
boxmaker
