Originally Posted by holeshot87
aslo is there something i can use that will shut the heater off when it get to the the right temp and ignite the heater when it gets below said 400. thx jim
i have NO idea if this would be helpful, but i thought i'd post it bc i rememberd coming across it... mcmaster-carr has a "remote heat controller":
"Just plug your heating equipment into one of these controllers and turn the adjustment knob to set. "On-off" cycling controls the amount of time a heater is on by proportioning electric power at line voltage. You should monitor your temperature with a separate thermometer. Controllers have a 6-ft. power cord with three-prong plug. Units operate on 115 VAC, and provide 115 VAC up to 1500 watts. The solid-state model reduces arcing of the switch contacts."
page 544 online catalog
