Re: Help with setting up tanks
Mark....This is the reply i had from caswell uk:
Martin,
The product is 91% sulphuric acid and the inclusions are organic digesters and not solvents. the Product does not purport to remove plastics or styrene's.
I have just finished a conversation with the manufacturers on this technical aspect and the posting on the forum is incorrect. You should get a Safety Data sheet with your product which will
One Shot Instant Drain Cleaner does not contain solvents and in all instances of customers and myself, in the early days, using the product I have had no problems and have not had adverse comments from the users.
Kind regards
So based on this info it seems 'ONE SHOT' is ok to use for the acid side of things.....Watch this space,the proof is in the pudding....I will report back after my first copper plating task!
