Search utility: "PH" too short
SO, I'm having a bit of a problem raising the PH levels. It was fine yesteday, but dropped overnight.
Trying to use the search for "PH" and it seems it's not a long enough string. At least three characters are needed.
Even searching "Ammonia ph" give the same results. Searcing only "ammonia" gives realatively few results.
How about shortening the string lenght to two characters so that a search for "PH" will bring up some results?
Yes, using ammonia. PH seems to be stuck at 3, even after letting it "rest", stirring and agitating. I've added what seems to be quite a bit of ammonia...and it won't go any higher.
