Mdarr:
Well, for the areas that are peeling it is most likely your cleaning is not atiquate enough. You can get a good plate on the part but if it is not clean enough it will disbond. A good plate will just about have to be chisled off.
The areas that are not plating are most likely your low current areas. Recesses and holes fall into this.
The only way to get these is to either make a aux. anode or use robbers on the high current areas and turn the power up so it will plate the lower current area.
The area you hang the part by will also be a low current area too.
Hope this helps
48 BUICK
